Additional administrative restriction - disable Generate session URL/code menu option
Is it possible to include the "Session > Generate session URL/code" menu option in the list of Administrative restrictions (https://winscp.net/eng/docs/administration#configuring).
And of course the result would be: after the required Reqistry change, the menu option would be disabled/greyed out.
Thank you!
J
Thank you!
J
