S3 file upload - Access Denied
ldowler
Victoria BC
I can connect to a S3 bucket and can download files but when I try to upload a file I get an "Access Denied" error.
Is there a way to set the encryption level. I suspect that is the issue but any other suggestions are welcome.
Re: S3 file upload - Access Denied
Can you upload the file using any other S3 client?
WinSCP does not support encryption levels.
ldowler
Yes I can upload with another S3 client. It uses SSE-S3(AES-256) which I understood to be the same as the default encryption level for WinSCP and S3 if I read the documentation correctly.
