Slow connection speed
H-BLOGX
Germany
hello,
we use WinSCP Version 5.17.10 (Build 11087) with about 20 configured connections. but normaly we use only 2 default connections. both connection will have IP adresses in the serveradress field and port 22. the server with the ip *.*.*.6 need about 30 secounds until the connection is up, the server with the ip *.*.*.7 only 2 secounds.
how can i monitor the problem,why server 6 use so much time?
kind regard h-blogx
H-BLOGX
Re: Slow connection speed
hello Martin, after your question i installed putty 0.74 and saw the same problem. it seams that the slower server has a "login process problem". how can i find that failure?
