feature request: resize "Keep Remote Directory up to Date..." dialog, sticky settings
jtmoonman
USA
Regarding the Keeping remote directory up to date... feature, two small feature requests.
Feature Request 1 - allow resizing the dialog
The current Keeping remote directory up to date... dialog does not allow resizing.
When the bottom-half log prints information for a longer path, it is hard to read. Also, it is difficult to scroll back through the history.
Would be great if the entire window could be resized to allow enlarging the bottom-half log output field.
Feature Request 2 - Transfer Settings is not sticky
I have created a Custom transfer setting, and then named it.
When I click Menu Commands -> Keep remote directory up to date..., then in the new dialog, click Transfer Settings drop down, the selected Preset is default.
I will then select the newly created custom Preset transfer setting. I will then Start In New Window. Later, I may have to stop and restart the Keep remote directory up to date... dialog.
However, almost every time, the Transfer Settings drop down, the selected Preset is default.
It would be a small convenience if the selected Preset was sticky, and preselected the last used custom-named Transfer Setting.
Great program, and the Keeping remote directory up to date... feature has really helped me out! :-)
Re: feature request: resize "Keep Remote Directory up to Date..." dialog, sticky settings
OK, I'll think about it. The dialog isn't really designed for resizing. It does not go well the the options part.
Are you asking for details specific to the "keep up to date" function? Or why don't you change the defaults?
