Log File Analysis
Hi Guys and Gals, I'm new to the forum and pretty green with the use of WinSCP although we have been using it for a couple or years so please be gentle.
We have started getting an issue with a script I have that gets a file on a daily basis from a 3rd parties SFTP server and we are not getting the file but apparently we are able to move it to a processed folder on the SFTP server 'well that's what I see when I manually logon and look in the processeed folder'.
I have turned on logging on the command line but cannot find any documentation that helps me decipher it.
Here is the log section that shows from the
I suspect that status code 1 is an error condition of some sort being that status code 0 in most applications is a success no errors.
If anyone can help it would be much appreciated.
Matt
get statement through to the close after the move.
2021-05-05 23:45:08.704 Script: get -nopermissions -nopreservetime *.csv C:\FTP\acompanyname\Inbound\Orders\ . 2021-05-05 23:45:08.704 Listing directory "/acompanyname/Orders". > 2021-05-05 23:45:08.704 Type: SSH_FXP_OPENDIR, Size: 32, Number: 267 < 2021-05-05 23:45:08.736 Type: SSH_FXP_HANDLE, Size: 12, Number: 267 > 2021-05-05 23:45:08.736 Type: SSH_FXP_READDIR, Size: 12, Number: 524 < 2021-05-05 23:45:08.751 Type: SSH_FXP_NAME, Size: 190, Number: 524 > 2021-05-05 23:45:08.751 Type: SSH_FXP_READDIR, Size: 12, Number: 780 < 2021-05-05 23:45:08.767 Type: SSH_FXP_STATUS, Size: 28, Number: 780 < 2021-05-05 23:45:08.767 Status code: 1 > 2021-05-05 23:45:08.767 Type: SSH_FXP_CLOSE, Size: 12, Number: 1028 . 2021-05-05 23:45:08.767 .;D;0;2021-05-05T22:00:02.000Z;"" [0];"" [0];rwxr-x---;2 . 2021-05-05 23:45:08.767 ..;D;0;2014-10-13T13:27:58.000Z;"" [0];"" [0];rwxr-x---;0 . 2021-05-05 23:45:08.767 afilename.xml;-;3277;2021-02-24T14:02:07.000Z;"" [0];"" [0];rwxr-x---;0 . 2021-05-05 23:45:08.767 PickedUp;D;0;2021-05-05T22:00:02.000Z;"" [0];"" [0];rwxr-x---;0 > 2021-05-05 23:45:08.767 Script: mv /acompanyname/Orders/*.csv /acompanyname/Orders/PickedUp/ . 2021-05-05 23:45:08.767 Listing directory "/acompanyname/Orders". > 2021-05-05 23:45:08.767 Type: SSH_FXP_OPENDIR, Size: 32, Number: 1291 < 2021-05-05 23:45:08.782 Type: SSH_FXP_STATUS, Size: 17, Number: 1028 . 2021-05-05 23:45:08.782 Discarding reserved response < 2021-05-05 23:45:08.798 Type: SSH_FXP_HANDLE, Size: 12, Number: 1291 > 2021-05-05 23:45:08.798 Type: SSH_FXP_READDIR, Size: 12, Number: 1548 < 2021-05-05 23:45:08.814 Type: SSH_FXP_NAME, Size: 190, Number: 1548 > 2021-05-05 23:45:08.814 Type: SSH_FXP_READDIR, Size: 12, Number: 1804 < 2021-05-05 23:45:08.829 Type: SSH_FXP_STATUS, Size: 28, Number: 1804 < 2021-05-05 23:45:08.829 Status code: 1 > 2021-05-05 23:45:08.829 Type: SSH_FXP_CLOSE, Size: 12, Number: 2052
Matt
