Is there an easy way to "script" a basic file copy from SFTP (DO) to a local folder...
intromatt
Bulgaria
..without actually opening up Notepad and writing code?
I just need to login to FTP then download a folder to local (only changed files) and perhaps have that on a timer (once a day?).
I am sorry to sound so ignorant...
Re: Is there an easy way to "script" a basic file copy from SFTP (DO) to a local folder...
I do not understand. How do you want to script something without writing a script (aka code)?
Anyway, do you know that WinSCP can generate a script template for you?
https://winscp.net/eng/docs/ui_generateurl#code
