Excel VBA throws error "Class Not Registered" even though WinSCPnet.dll is successfully registered
In the following text eight pictures are referenced. These are various screen shots relevant to this problem. They are in a single zip file,
When VBA code encounters the first instance of an instruction that uses WinSCPnet.dll, it throws the error "Class Not Registered". Here is an image of the error
The VBA code has worked for two months just fine. I don't believe there is any error in the VBA code. This error started after I downloaded a change to the operating system.
After the download, since the problem existed, I updated WinSCP. Here is the folder containing both WinSCP and WinSCPnet.dll.
WinSCPnet.dll file:
After update to the current version of WinSCP, the program worked just fine. No problems. However the "Class Not Registered" Excel problem persisted.
I proceeded to register WinSCPnet.dll. First I used RegAsm.exe. Here is the RegAsm program in its folder:
For further information, in case it is relevant, here is the folder for the Microsoft.Net folder list:
Also, here are the versions I am now using:
1. WinSCP – 5.17.10.11087
2. Last version – Don’t know last version, but was the latest before current version
3. Microsoft OS – Windows 10 Pro, Version 20H2, Build 19042.928
Could this problem be due to a bad version of WinSCPnet.dll?
Problem Pictures.zip. The pictures are in bmp format. Each picture file name begins with 01 through 08. They are in order of reference in the text.
01 Class Not Registered.bmp.
02 WinSCP Folder.bmp. Here are the properties for the WinSCP file: 03 Winscp Properties.bmp. Here are the properties for the
WinSCPnet.dll file:
04 Winscpnet.dll.bmp.
05 After Regasm Add.bmp. Here is the CMD code to perform the registration. 06 CMD Registration.bmp. Here is the Excel Reference display, which shows a correct registration. 07 Wrapper Registrated.bmp
