WinSCP process terminated with exit code 1.
rainmanec
China
WinSCP process terminated with exit code 1. Error output was "Can't open log file 'C:\Users\Administrator\AppData\Local\Temp\1\wscp14A4.03F1F5CA.tmp'.
System Error.  Code: 2.
The system cannot find the file specified。
Error occurred during logging. Cannot continue.". Response log file C:\Users\Administrator\AppData\Local\Temp\1\wscp14A4.03F1F5CA.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
This problem does not occur every time, restarting the application still exists, and need to restart the computer to solve it
rainmanec
China
Re: WinSCP process terminated with exit code 1.
The directory C:\Users\Administrator\AppData\Local\Temp\1 does not exist.
After manually creating the directory, the program runs successfully.
Why WinSCP can not create folder automatically sometimes?
Thanks!
WinSCP does not create the directory. Why would it? It creates the log either implicitly in the the Windows temporary folder or to folder you tell it using Session.XmlLogPath.
If first case, the temporary folder must exists. If it does not, your machine is misconfigured and you must have lot of other problems. Or you told WinSCP explicitly to uses a non-existing path.
