Disable option "remember last used directory" in generating session URL/code
aixtreme
Germany
Found no information how to store the advanced environment setting "Remember last used directory" = false while generating session URL/code.
UpdateDirectories=0 is not working.
Thanks for your assistance
aixtreme
Re: Disable option "remember last used directory" in generating session URL/code
It should be working. Show us your code.
Though the option is not really relevant for scripting/code. What are you trying to achieve?
