Access denied
Stuart.Jolley
uk
Access denied
I've just started using WinSCP and think its a great tool. I'm using it to pass files around various networked PCs.
On one PC which is part of a domain I'm synchronizing files to another PC within a workgroup over the network.
Using the GUI, I can make a connection and transfer the files manually. All works ok except the connection keeps timing out and reconnecting and sometimes asking for the password again. I also can't delete files from the destination, access denied!!
Ultimately I want to use a script to transfer files on a routine basis but the script does work. The script works good on one PC so I know the contents is correct, when on this PC it doesn't work, although I have changed the connection details.
Log states
. 2021-05-12 16:16:46.194 --------------------------------------------------------------------------
. 2021-05-12 16:16:46.195 Looking up host "x.x.x.x" for SSH connection
. 2021-05-12 16:16:46.195 Connecting to x.x.x.x port x
. 2021-05-12 16:16:46.198 We claim version: SSH-2.0-WinSCP_release_5.17.10
. 2021-05-12 16:16:46.198 Remote version: SSH-2.0-WeOnlyDo 2.5.5
. 2021-05-12 16:16:46.198 Using SSH protocol version 2
. 2021-05-12 16:16:46.199 Have a known host key of type rsa2
. 2021-05-12 16:16:46.208 Doing ECDH key exchange with curve Curve25519 and hash SHA-256
. 2021-05-12 16:16:46.248 Server also has ssh-dss host key, but we don't know it
. 2021-05-12 16:16:46.248 Host key fingerprint is:
. 2021-05-12 16:16:46.248 ssh-rsa 1024 18:a9:3e:4c:c5:4f:a4:d6:18:72:78:2d:c7:8c:1b:61 v4yfKd4Z2F+zeFpj8ed08L3HZoR+2a4q38k+h+5Jf6k=
. 2021-05-12 16:16:46.249 Host key matches configured key fingerprint
. 2021-05-12 16:16:46.249 Initialised AES-256 SDCTR (unaccelerated) outbound encryption
. 2021-05-12 16:16:46.249 Initialised HMAC-SHA-256 outbound MAC algorithm
. 2021-05-12 16:16:46.250 Initialised AES-256 SDCTR (unaccelerated) inbound encryption
. 2021-05-12 16:16:46.250 Initialised HMAC-SHA-256 inbound MAC algorithm
! 2021-05-12 16:16:46.250 Using username "xxxx".
. 2021-05-12 16:16:46.251 Server offered these authentication methods: password
. 2021-05-12 16:16:46.251 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2021-05-12 16:16:46.251 Using stored password.
. 2021-05-12 16:16:46.251 Sent password
. 2021-05-12 16:16:46.252 Password authentication failed
! 2021-05-12 16:16:46.252 Access denied
. 2021-05-12 16:16:46.252 Server offered these authentication methods: password
. 2021-05-12 16:16:46.252 Prompt (password, "SSH password", <no instructions>, "&Password: ")
. 2021-05-12 16:16:46.252 User aborted during password authentication
. 2021-05-12 16:16:46.253 Attempt to close connection due to fatal exception:
* 2021-05-12 16:16:46.253 **Connection has been unexpectedly closed.** Server sent command exit status 0.
. 2021-05-12 16:16:46.253 Closing connection.
any help would be appreciated
Re: Access denied
I'm not sure if you talk about two different servers or two different client (local) machines.
Re: Access denied
Then I do not understand what you mean by "The script works good on one PC ..., when on this PC it doesn't work", if you connect from one client to one server only. So when does it work and when not?
