Timeout occurred when connecting to WinSCP
pavanmanideep
Hyderabad
I was able to upload to FTP from my local but not from Windows server. Can you please suggest what could be wrong...Below is the log created...
Can you once check and let me know on this..
Error while creating csv file for notification type - 1 and error details are - WinSCP.SessionRemoteException: Connection failed.
Connection failed.
at WinSCP.SessionLogReader.Read(LogReadFlags flags)
at WinSCP.ElementLogReader.Read(LogReadFlags flags)
at WinSCP.SessionElementLogReader.Read(LogReadFlags flags)
at WinSCP.CustomLogReader.TryWaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.CustomLogReader.WaitForNonEmptyElement(String localName, LogReadFlags flags)
at WinSCP.Session.WaitForGroup()
at WinSCP.Session.Open(SessionOptions sessionOptions)
at Hitachi.CDC.PushNotifications.PushNotifications.fileuploadwinscp(String fileName, String localpath)
at Hitachi.CDC.PushNotifications.PushNotifications.createCSV(DataTable dt, Boolean SMS, Boolean Mobile, Int32 eventType, Int32 notificationTypeFile)--InnerException-----Message---Connection failed.
Connection failed.--StackTrace--- at WinSCP.SessionLogReader.Read(LogReadFlags flags)
Thank you.
Re: Timeout occurred when connecting to WinSCP
Can you connect from the server using WinSCP GUI? Or any other client using the same protocol?
SandeepKr
Timeout Error
Hello ,
From Server when we connect manually we are able to connect and update. After some idle time there is a popup message Software caused error .Do you want to reconnect. ?
