Sorting a remote directory
JonWayn70
Bellingham, WA
Is there a way to sort a remote directory, using a script command, so that the ls command will return the listing in the order you want? Thank you
Re: Sorting a remote directory
You better use WinSCP .NET assembly (e.g. from PowerShell) if you want to customize the output anyhow.
For an example, see:
https://winscp.net/eng/docs/script_custom_listing_format_csv
For sort the file for example by time, use:
$directory = $session.ListDirectory($remotePath)
$files = $directory.Files | Sort-Object LastWriteTime -Descending
foreach ($fileInfo in $files)
