Long dash in remote directory
TimB
I am using a script to download files from a remote directory.
In WinSCP it works fine. From the WinSCP GUI I create the script. In the script following remote directory needs to be accessed
    "cd ""/Radio Productiehuis UPLOAD/Steve DeKoning – De Vlaamse EXTRA 15""" ^
Now when running the script following error appears
Fout tijdens wisselen van map naar '/Radio Productiehuis UPLOAD/Steve DeKoning ÔÇô De Vlaamse EXTRA 15'.
/Radio Productiehuis UPLOAD/Steve DeKoning ÔÇô De Vlaamse EXTRA 15: No such file or directory.
As you can see the dash is not properly transferred. So I change it to a normal dash but it seems to be shorter in length.
    "cd ""/Radio Productiehuis UPLOAD/Steve DeKoning - De Vlaamse EXTRA 15""" ^
vs
Anyway the error is the same, path is not found properly because the dashes don't match.
Any solution?
