I am getting "terminated by user" / "time out waiting for server to respond" errors
sachink
india
I am getting "terminated by user" / "time out waiting for server to respond" / "software caused connection abort" errors, when I try to upload files from my local to clients SFTP server. First I create a file locally, then move to client's SFTP server. Most of the files get uploaded but few of them error out with this error. Attached is the session log file.
Re: I am getting "terminated by user" / "time out waiting for server to respond" errors
You seem to be getting the errors when connecting, not while transferring. The server might be overloaded temporarily or there can be a temporary network issue. You might just need to retry the connection.
sachink
Thanks for the reply... what do you mean when you say "you just need to try the connection".. it is auto task that runs daily and transfer files from source to destination.
