(ExtException) **Copying files to remote side failed.**
d1rk
USA
I've been running large file transfers using:
synchronize remote -resumesupport=on
From time to time I get:
Connecting to XX.XXX.XXX.XX:XXXXX ...
550 The process cannot access the file because it is being used by another process.
Asking user:
Error transferring file 'D:\Folder\Folder\file.xxx'. ("Copying files to remote side failed.","The process cannot access the file because it is being used by another process. ")
< 2021-06-03 08:21:31.430 Script: Copying files to remote side failed.
Questions: Is the file that is in use on the local side or the remote side?
Any advice on how to mitigate this problem? Thanks!
Re: (ExtException) **Copying files to remote side failed.**
The error comes from the server, so it refers to the remote file.
