Script get -delete not working
RCMeg
I'm trying to automate (via batch file) downloading and deleting all files from a remote directory. The files are just in the / <root> and are downloading to a local drive.
WinSCP gives me this, and I add in the -delete switch:
  /log="C:\writable\path\to\log\WinSCP.log" /ini=nul ^
  /command ^
    "SFTP CONNECTION INFO HERE" ^
    "cd /" ^
    "lcd C:\working\Work" ^
    "get -delete *" ^
    "exit"
if %WINSCP_RESULT% equ 0 (
  echo Success
) else (
  echo Error
exit /b %WINSCP_RESULT%
Even without the delete switch, the get command does nothing. With it, it also does nothing, and does not download nor delete them. Can anyone help?
Re: Script get -delete not working
