Press 'Delete' to delete the file and create new one instead of overwriting it
jkexbx
I'm trying to create a script to automatically upload files to a SFTP site. I want it to upload new copies if the file size if different, or just upload everything new each time. Sorry for all the cleansing I had to do.
The command I'm running is below and this will upload new files fine. But if the file already exists it gives the below error message.
/command " option batch continue" "open sftp://######:######@######//" "put ""C:\##########\*"" ""/##########/""" "exit"
. 2021-06-09 14:05:39.856 File: 'C:\#######\Log_201804_001.xls' [2020-06-22T12:51:39.850Z] [53248]
. 2021-06-09 14:05:39.858 Copying "C:\#######\Log_201804_001.xls" to remote directory started.
. 2021-06-09 14:05:39.858 Binary transfer mode selected.
. 2021-06-09 14:05:39.858 Opening remote file.
> 2021-06-09 14:05:39.858 Type: SSH_FXP_OPEN, Size: 71, Number: 11011
< 2021-06-09 14:05:39.936 Type: SSH_FXP_STATUS, Size: 36, Number: 11011
< 2021-06-09 14:05:39.936 Status code: 3, Message: 11011, Server: Permission denied, Language: en
> 2021-06-09 14:05:39.937 Type: SSH_FXP_LSTAT, Size: 55, Number: 11271
< 2021-06-09 14:05:39.977 Type: SSH_FXP_ATTRS, Size: 37, Number: 11271
* 2021-06-09 14:05:39.978 (ETerminal) Permission denied.
* 2021-06-09 14:05:39.978 Error code: 3
* 2021-06-09 14:05:39.978 Error message from server (en): Permission denied
. 2021-06-09 14:05:39.978 Asking user:
. 2021-06-09 14:05:39.978 Cannot overwrite remote file '/########/Log_201804_001.xls'.$$
. 2021-06-09 14:05:39.978 Press 'Delete' to delete the file and create new one instead of overwriting it.$$ ("Permission denied.
. 2021-06-09 14:05:39.978 Error code: 3
. 2021-06-09 14:05:39.978 Error message from server (en): Permission denied")
< 2021-06-09 14:05:39.978 Script: Cannot overwrite remote file '/#######/Log_201804_001.xls'.
< 2021-06-09 14:05:39.978 Script: Permission denied.
< 2021-06-09 14:05:39.978 Error code: 3
< 2021-06-09 14:05:39.978 Error message from server (en): Permission denied
* 2021-06-09 14:05:39.979 (ESkipFile) Cannot overwrite remote file '/######/Log_201804_001.xls'.$$
* 2021-06-09 14:05:39.979 Press 'Delete' to delete the file and create new one instead of overwriting it.$$
* 2021-06-09 14:05:39.979 Permission denied.
* 2021-06-09 14:05:39.979 Error code: 3
* 2021-06-09 14:05:39.979 Error message from server (en): Permission denied
Re: Press 'Delete' to delete the file and create new one instead of overwriting it
I'm not sure what your question is. You seem to try to overwrite a file, for which you do not have write permissions.
jkexbx
MY apologizes! I do not have permission to overwrite a file, but I do have permission to delete them. I was wondering how I get it to perform the "Press 'Delete' to delete the file and create new one instead of overwriting it."
