Error saving file on tunneled connection
raddy
I have set up a connection through a SSH tunnel with WinSCP 5.19, using local tunnel port 50002.
Whenever I open a file using internal or external editor and try to save it, I get the following error:
Error while tunneling the connection.
Local port 50002 forwarding to 192.168.1.100:22 failed: Network error:
Address already in use
Can you help, thanks!
Re: Error saving file on tunneled connection
You actually cannot fix the tunnel port number, if you want to use the background transfers (needed for editing). Keep the Autoselect option.
