Upgrading from 5.17.10 to 5.19: synchronize: CWD failed.
Patrick1150
Fribourg
Task:
Downloading new files from the server.
Script:
# embryocd/download: download all except .exe
synchronize local d:\xampp\htdocs\arimipu\embryocd\download /embryocd/download -criteria=time -filemask="|*.exe"
Error Messages:
Lokal „d:\xampp\htdocs\arimipu\embryocd\download“ <= Entfernt „/embryocd/download“
Synchronisieren …
embryocd                  |            0 B |    0.0 KB/s | binary |   0%
Fehler beim Anzeigen des Verzeichnisses „/embryocd/download//embryocd“.
Verzeichnisinhalt konnte nicht abgerufen werden
CWD failed. "/embryocd/download/embryocd" : no such file or directory.
A(b)brechen, (W)iederholen, Über(s)pringen, (A)lle überspringen: Überspringen
download                  |            0 B |    0.0 KB/s | binary |   0%
Fehler beim Anzeigen des Verzeichnisses „/embryocd/download//embryocd/download“.
CWD failed. "/embryocd/download/embryocd/download" : no such file or directory.
Vergleichen …
Synchronizing NO subdirs resolves (temporarily) the problem:
# embryocd/download: download all except .exe; but no subdirs (|*/)
synchronize local d:\xampp\htdocs\arimipu\embryocd\download /embryocd/download -criteria=time -filemask="|*.exe; */"
Any ideas to resolve the problem?
Re: Upgrading from 5.17.10 to 5.19: synchronize: CWD failed.
So do you mean that with 5.17.10 your script was working and with 5.19 it does not? Please attach a full session log files from both versions.
Patrick1150
Fribourg
Hello Martin
Exactly, the files are not downloaded.
Therefore I included the error messages to fix the problem.
Task: download all files from /embryocd/download, -filemask="|*.exe"
WinSCP tries (it doubles somehow the path):
1) /embryocd/download//embryocd
=> CWD failed. "/embryocd/download/embryocd" : no such file or directory.
2) /embryocd/download//embryocd/download
=> CWD failed. "/embryocd/download/embryocd/download" : no such file or directory.
Downloading all files from /embryocd/download, but NO subdir, works!
=> -filemask="|*.exe; */"
Regards, Patrick
"Please attach a full session log files from both versions."
