What types of files can I upload using the WinSCP shell?
mzimmer
TL;DR: How can I upload a file that has periods in the filename?
I have a file I'm trying to upload to the sftp site using the WinSCP shell. And its not working.
The shell crashes without any error message and the file does not upload.
The filename has the period character to separate the month,day,year in a date.
The filename looks like this: groceries 6.22.2021.xlsx
When I replace the periods with forward slashes, the file uploads successfully.
The successful filename looks like this: groceries 6/22/2021.xlsx
Does WinSCP support uploading files with periods? How can I upload this file as it needs to be in the period format for downstream reasons.
Thanks!
Re: What types of files can I upload using the WinSCP shell?
Of course that WinSCP does support uploading files with periods in their names. After all, almost all files do have periods in their names.
mzimmer
Hi Martin,
Thanks for your response. I was able to fix the problem by changing the code which generates the filename from formatting the date as "mm.dd.yyyy" to "m.d.yyyy", and it worked.
Best
