Dynamic drive letter, require no restart.
web5
mars
i'm using ram disks, and just notice
that winscp will not update the list
of available drives in system after
i create one like ram-disk, and
had to restart winscp.
You could:
- implement awareness of active drives.
Thanks.
Re: Dynamic drive letter, require no restart.
WinSCP refreshes the drive list, when a new drive is attached or removed. Maybe your "ram-disk" tool does not notify about the attached drive properly. I've just tested WinSCP with ImDisk and it works as expected. What tool do you use?
web5
mars
Using SoftPerfect RAM Disk, and
you may be right, since i had couple
of win10 blue screen with reboot after i
tried to mound .iso with windows explorer.
Just maybe you test with this one to be sure.
Thanks.
web5
mars
Yes:
- Explorer [ Eindows]
- totalcmd
except in WinSCP.
Plan on fresh windows install in VirtualBox,
then will test and report back.
Or you can test by yourself, and
confirm it's not just me.
web5
mars
WinSCP-5.19.2
Just updated, and did testing, and
notice that RAM disk with letters A: and B:
are ignored, and not refreshed in the list,
while other assigned letters to the RAM disk
are appearing in the drive list as it should.
I'm using SoftPerfect RAM Disk on Win10x64.
