connect timeout using WinSCPNet in web application
NoBullMan
USA
I am working on a web application where one function is to connect to a remote Linux server using SFTP, download some log files, parse and display the results. I am using WinSCP to achieve this.
I got this working and tested it running from VS in my local dev box (Windows 10). I published it to a test server running Windows 2012 R2 and it fails to connect. It throws:
Timeout waiting for WinSCP to respond - WinSCP has not responded in time. There was no output. Response log file C:\Windows\TEMP\wscp3BFC.0292A297.tmp was not created.
I searched and it seems in IIS, impersonation had to be off and I had it on; that change did not fix the issue either although WinSCP support page lists it as a fix.
When I remote to test server, open IIS, select the application and run it from there it works fine; so I know there are no issues with user ID, password, port or host key fingerprint. I spent the whole day and am at at wit's end. Some ideas is most welcome.
This is the code I am using:
public SFTP(string sHost, int iPort, string sUserID, string sPassword, string SshHostKeyFingerprint, string ExePath)
    SFTP_Host = sHost;
    SFTP_Port = iPort;
    SFTP_UserID = sUserID;
    SFTP_Password = sPassword;
    SFTP_SshHostKeyFingerprint = SshHostKeyFingerprint;
    ExePath = ExePath;
public void ConnectSFTP()
    // Set up session options
        Protocol = Protocol.Sftp,
        HostName = SFTP_Host,
        PortNumber = SFTP_Port,
        UserName = SFTP_UserID,
        Password = SFTP_Password,
        SshHostKeyFingerprint = SFTP_SshHostKeyFingerprint
    sessionOptions.AddRawSettings("Cipher", "aes,chacha20,3des,WARN,des,blowfish,arcfour");
    SFTP_Session = new Session();
    SFTP_Session.ExecutablePath = ExePath;
    //SFTP_Session.XmlLogPath = "Z:\\Data\\WinSCP.xml";
    //SFTP_Session.SessionLogPath = @"Z:\Data\WinSCP.log";
    // Connect
    try
        SFTP_Session.Open(sessionOptions);
        TraceLog.appendTransactionLog("Connected to " + SFTP_Host + ":" + SFTP_Port);
    catch (Exception ex)
        TraceLog.appendTransactionLog("Failed to connect to " + SFTP_Host + ":" + SFTP_Port + Environment.NewLine + "Error: " + ex.Message);
    finally
        if (SFTP_Session != null)
            SFTP_Session.Dispose();
It is called like this:
SFTP client = new SFTP(sftpHost, iSftpPort, sftpUserID, sftpPassword, sshHostKeyFingerprint, ExePath);
client.DownloadFiles();
public string DownloadFiles()
    ConnectSFTP();    // FAILS HERE ...
    try
        using (SFTP_Session)
            SFTP_Session.QueryReceived += (sender, e) =>
            e.Continue();
    catch (Exception e)
    finally
I see in my log file (not WinSCP since it can connect):
2021-07-02 08:24:56:169|Failed to connect to 1.2.3.4:22 (ssh-ed25519-hK8U-......)
Error: Timeout waiting for WinSCP to respond - WinSCP has not responded in time. There was no output. Response log file C:\Windows\TEMP\wscp3BFC.0292A297.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
WinSCP version is 5.17.10.0.
