Date added to text files last line
simko
When I try to edit a text file - especially CSS files - with the external file editor there is a new line at the bottom of the text file with the actual datetime of the opening.
For example my file before editing the last lines:
.login .privacy-policy-page-link {
  margin: 0;
  margin-top: 1rem;
When I open it from WinSCP this line added to the bottom with an empty line after it:
  margin: 0;
  margin-top: 1rem;
8:22 2021. 07. 06.
What can cause the problem?
WinSCP version: 5.19.1 (Build: 11552)
Re: Date added to text files last line
If you download the file and check the downloaded file contents, does it also contain that line?
