Re-sort hides top file
Bob6S50Yf
for a folder listing of (100+ files), e.g.
A
B
C
ZY
ZZ
When click on and re-sort descending, the ZZ file is obscured because the focus is on ZY. To see the ZZ file, you have to scroll up.
Proposed:
If the currently selected file is number 2 then the scroll view should be 'at the top'.
This could be the same rule for any file less than 10. e.g.
If the currently selected file is number 9 then the scroll view should be 'at the top'.
Re: Re-sort hides top file
What do you "click on"? The ZY?
