PowerShell script failing
traveller198
UK
Hi All,
I have the following script to upload the newest file from a number of subfolders. The script lists the files to upload but then fails to upload them with the error:
Uploading "Filename of first file" ...
Error: Exception calling "Check" with "0" argument(s): "File or Folder 'Filename of first file' does not exist.
System error. Code: 2.
The system cannot find the file specified"
Script:
try
    # Load WinSCP .NET assembly
    Add-Type -Path "WinSCPnet.dll"
    # Setup session options
        HostName = "FQDN of host"
        UserName = "USER"
        Password = "PASS"
        SshHostKeyFingerprint = "FINGERPRINT"
    try
        # Connect
        $remotePath = "REMOTE PATH"
        $lines = Get-ChildItem -Path I:\path\to\toplevelfolder -Recurse -File -Filter *.bak | group directory | foreach {$_.group | sort LastWriteTime -Descending | select -First 1}
        foreach ($line in $lines)
            Write-Host "Uploading $line ..."
            $session.PutFiles($line, $remotePath).Check()
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Could any one provide advise as to why the error is returned and the selected files are not uploaded? $lines does seem to provide the correct files for upload so not sure where I have gone wrong here.
