Blank File Download
Urqsb
Blank File Download
I have an issue when downloading a file via FTP TLS/SSL Explicit encryption using the GUI or a script. I am using version 5.19.1 on Server 2012R2.
The file shows as 1kb but when downloaded or edited it is empty. If I use FileZilla the file is transferred with data in it.
I've attached a log file.
Please could you take a look?
  • log.txt (10.75 KB, Private file)
Re: Blank File Download
The log shows that 604 bytes were downloaded. How exactly do you check the file size after the download? What does dir E:\SageImport\WebOrder5038.csv show?
Urqsb
Thanks for coming back to me. The file is 0KB and the file is empty when I open or view in the GUI. I have attached a screenshot.
  • WinSCP.JPG (26.7 KB, Private file)
Isn't there a local process that might monitor the "import" folder and conflict with WinsCP download?
If you are sure that there's no such process, I have sent you an email with a debug version of WinSCP to the address you have used to register on this forum.
