Close session shortcut (Shift+Ctrl+D) not working
gregor
Using version 5.19.2 (build 11642)
When I have an active session connection the short-cut key sequence Shift+Ctrl+D no longer closes the session.
Re: Close session shortcut (Shift+Ctrl+D) not working
Works for me. Can you double check? Does it work in 5.19.1? Or in what version was it still working for you?
gregorSc
I have re-checked and it still does not work in 5.19.2
It was working in 5.19.1
I'm using Windows 10.
Could something else be hijacking the shortcut?
