How to create a new topic at winscp.net ??
Jacob1
Do you click "Submit" and nothing happens?
I guess that you write a comment and when you click "Submit" nothing happens. Is that correct?
If this is the case, and you are in China, I surmise that the Google's ReCaptcha, which is necessary for submitting a question/comment, does not work since Google is frequently blocked in your country.
gordy57
Uk
Cannot Post a Question
I'd really like to post a new question to this forum. But where do I do this? The closest I've found is responding to an existing topic, but not starting a new one.
What I really wanted to ask on the forum (and I may as well ask it here: you never know), what I wanted to ask on the forum was why my Upload button has suddenly disappeared and is now replaced by a button which says "Copy" (see second screenshot also attached - the button on the far left and below used to be called "Upload" ),
And if you click on that there is another option for it to say "Move". Both of these functions are useless, of course, because I need to be able to upload files using FTP, which is what this FTP client is for (although I see that it has some other functions as well).
So basically the Upload button has disappeared. Does anyone know how to get it back?
