Installing over old version
Hi, Simple question. (I have read the FAQ.) I am using an old version of WinSCP (4.2.7). Win 10 Pro, 32 bit, Commander interface. Can I install the latest version on top of the old one, or do I need to uninstall the old one first? And in either case, will the connections/logins I have on the old version be preserved? (I have stuck with the old version because it works and I have always found setting up connections difficult.). Thanks very much.
