FTP Script quit working
pcnet
PCNET
Can you please help me with this? All of sudden this stopped working. I tried 2 different FTP server locations so I think it is with my script or WinSCP changed. I masked out IP addresses and user/passwords.
Thank you for your help.
Script:
@echo off
echo option batch continue>> ftpcmd.dat
echo option confirm off>>ftpcmd.dat
echo open ftpes://user_goes_here:password_goes_here@servername/ -passive=off -certificate="d7:68:23:ee:cc:aa:aa:00:ee:0f:0c:2b:12:b8:dd:44:77:44:33:22">> ftpcmd.dat
echo get -transfer=bin %1 .\>> ftpcmd.dat
echo exit>>ftpcmd.dat
winscp.com /log="F:\logs\get_ftp.log" /ini=nul /script=ftpcmd.dat
del ftpcmd.dat
Here is the error:
. 2021-07-28 15:34:53.246 Using FTP protocol.
. 2021-07-28 15:34:53.247 Doing startup conversation with host.
< 2021-07-28 15:34:53.247 Script: Starting the session...
> 2021-07-28 15:34:53.248 PWD
< 2021-07-28 15:34:53.278 257 "/" is your current location
. 2021-07-28 15:34:53.279 Getting current directory name.
. 2021-07-28 15:34:53.280 Startup conversation with host finished.
< 2021-07-28 15:34:53.280 Script: Session started.
< 2021-07-28 15:34:53.281 Script: Active session: [1] user@server_here
> 2021-07-28 15:34:53.281 Script: get -transfer=bin * .\
. 2021-07-28 15:34:53.282 Retrieving directory listing...
> 2021-07-28 15:34:53.284 TYPE A
< 2021-07-28 15:34:53.313 200 TYPE is now ASCII
> 2021-07-28 15:34:53.315 PASV
< 2021-07-28 15:34:53.347 227 Entering Passive Mode (99,99,99,99,202,246)
> 2021-07-28 15:34:53.347 MLSD
. 2021-07-28 15:34:53.347 Connecting to 99.99.99.99:51958 ...
< 2021-07-28 15:34:53.409 150 Accepted data connection
. 2021-07-28 15:34:53.444 Data connection closed
. 2021-07-28 15:34:53.444 <Empty directory listing>
. 2021-07-28 15:34:53.475 Disconnected from server
. 2021-07-28 15:34:53.476 Could not retrieve directory listing
. 2021-07-28 15:34:53.477 Connection was lost, asking what to do.
. 2021-07-28 15:34:53.477 Asking user:
. 2021-07-28 15:34:53.477 **Lost connection.** ("Disconnected from server","Could not retrieve directory listing")
< 2021-07-28 15:34:53.478 Script: Lost connection.
< 2021-07-28 15:34:53.478 Script: Disconnected from server
< 2021-07-28 15:34:53.479 Could not retrieve directory listing
Re: FTP Script quit working
I do not think it's your script or WinSCP. It's rather your FTP server or some firewall/NAT on the way. Can you connect to the FTP server using WinSCP GUI or any other FTP client, from the same machine that runs your WinSCP script?
