PowerShell options
Burtamus
IA
PowerShell options
I'm trying to write a PowerShell Script to upload a newly created file. When I attempt to do so, it says...
Error: Exception calling "Check" with "0" argument(s): "Cannot overwrite remote file '/<filename>.ldif'.$$
Press 'Delete' to delete the file and create new one instead of overwriting it.$$
No such file or directory.
Error code: 2
Error message from server (US-ASCII): /<filename>.ldif"
I've been told to do two things...
  • For the Enable transfer resume/transfer to temporary filename for option, choose Disable.
  • For Transfer, choose Background, and clear the Use multiple connections for single transfer check box.
Easy enough in the GUI (BTW, the GUI works fine, not the PowerShell tho). How do I set these options in PowerShell? Examples greatly appreciated.
Re: PowerShell options
Who did you tell that? Why do you think these options are relevant?
Burtamus
IA
Sorry, I did not tell anyone that. It was told to me that the SFTP host required it set that way. I'll say again that the GUI works perfectly fine for uploading, it is just the command line that is having this issue.
Is there no documentation on how to set those options via the command line? It took me a week, but I finally found a way to log to a file. I'll work at getting that uploaded. Documentation on the command line is sadly lacking.
Thanks, Burt
Burtamus
IA
This is the script I'm using to do the upload...
try {
    # Load WinSCP .NET assembly
    Add-Type -Path ".\WinSCPnet.dll"
    # Setup session options
        HostName = "sftp.*****.com"
        UserName = "*****"
        SshHostKeyFingerprint = "ssh-rsa 2048 *****"
        SshPrivateKeyPath = "D:\Source\*****.ppk"
    try {
        # Connect
        $session.SessionLogPath = ".\$($Filename).log"
        $transferOptions.TransferMode = [WinSCP.TransferMode]::ASCII
        $transferOptions.ResumeSupport.State = [WinSCP.TransferResumeSupportState]::Off
        $transferResult = $session.PutFiles($FileName, "/", $False, $transferOptions).Check()
    finally {
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch {
    exit 1
Your code already does that.
This is irrelevant for the .NET assembly, as it never uses multiple connections on its own.
So your problem must be elsewhere. Please post session log file from WinSCP GUI showing a successful upload.
Burtamus
RESOLVED!
The issue was the remote path. Instead of just using /, the server was looking for ftp://<user>@<server>. This can be found in the GUI under Session/Generate Session URL.
J0ska
Had the same problem using Session.PutFiles method. The issue in my case was that remote path /dir1/dir2 did not ended with / therefore dir2 was interpreted as file name.
