View won't save
Hooch
US
View won't save
v 5.19.2 (Build 11614)
Win 10 PC
Commander view
Tree display
Queue = Show
Session saved as Site (SFTP)
Got a new laptop, reinstalled WinSCP, used the WinSCP.INI to transfer settings. My problem:
Every time I open WinSCP the Local panel (USB drive) shows Name then Size (instead of Name then Changed as last set and saved it) and the Name column width is reduced. Also, the queue column widths for Source and Destination have been reset so they are much narrower than when I WinSCP closed.
Thanks in advance for any thoughts as to what happened and how to make the bad man stop.
Re: View won't save
