v5.19.2 - Keeps removing file.
Trex2303
When I'm editing a file (using Notepad++) after I edit and save it a couple of times then do another edit, it gives me an error saying the file doesn't exist anymore, even though it does because I just opened it to edit it...
The internal editor always adds spaces every time you save, that's why I use Notepad++, it doesn't add the spaces. Otherwise, I sometimes get an error message that I can't edit the file and run it as admin, but then it won't even save.
Description: doesnt exist
Description: cantsave
Re: v5.19.2 - Keeps removing file.
