WinSCP not able to connect to a server. Searching for host then it timeouts
Ubilyat
https://winscp.net/eng/docs/faq_connection_refused I tried this and it's still not working
I didn't change anything in WinSCP and it just stopped working (it used to connect)
I did update it but it worked after updating (as far as I remember)
but now It just won't work
I can connect to the host through their panel and everything
I didn't change the settings and I made sure that everything is correct
it just searches then says "timed out"
Ubilyat
Reinstalling the machine fixed it
I apparently removed something in the ubuntu machine so I just reinstalled it and now I can connect.
