Scheduling not works on Windows Server 2016
jroberto
Hi folks,
I have 2 problems, first I'm not able to schedule a task in which the script use the keepuptodate command, it seems that the task starts but stops working.
Second, if I launch this same bat file directly from the command line, it works, but after a while the session is terminated by the server.
Any way to solve these problems?
Re: Scheduling not works on Windows Server 2016
1) Please attach a full session log file showing the problem (using the latest version of WinSCP).
2) See https://winscp.net/eng/docs/script_retry
