How to use WinSCP connect the AWS S3 drive
Re: How to use WinSCP connect the AWS S3 drive
Yes, but I think I should follow this content:
Similarly, when your access key does not have permissions to list buckets, you will need to specify the path to the desired bucket the same way. In scripting, you do that by appending the path to the bucket to a session URL: s3://accesskey:secretkey@s3.amazonaws.com/bucket/."
Is there a sample of the script?
