"Client Hostname" pattern for XML logs?
WilliamFields
I occasionally run WinSCP from multiple workstations. The XML logs are configured with the same folder so I get conflicts when the two WinSCP instances try to write to the same log.
To keep my WinSCP configurations generic and consistent, it would be very helpful to have a "client hostname" pattern available. Perhaps !C@ would work.
For example:
C:\Users\bfields\OneDrive\Documents\WinSCP\!S-!C@.xml
That would create a log file with the session name and client hostname.
Thanks.
