Connection Failed
gerrbear
OH
Connection Failed
This week, after using WinSCP for quite a while I received a 'Connection Failed' error. I recently starting using Bitdefender which I thought might be the issue. I checked the rules and added a rule to allow winscp.exe through. This did not fix the issue.
I have checked the following:
1) Bitdefender firewall (allowed rule)
2) Windows firewall (off)
3) I use Chrome and nothing is blocking it that I can locate
4) Checked the forums as best I could
I am at a loss how to fix this issue. Please assist me.
Re: Connection Failed
Please post session log file.
Can you connect to that server using any other client using the same protocol? If you can, post its log file too.
Reply to Connection Failure
1. The log file was not logging. Once I checked the box, here are the results
2. I installed Cyberduck but never used it as honestly I was not sure how to log into it.
. 2021-09-23 13:29:19.350 --------------------------------------------------------------------------
. 2021-09-23 13:29:19.352 WinSCP Version 5.19.2 (Build 11614) (OS 10.0.19043 - Windows 10 Home)
. 2021-09-23 13:29:19.352 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2021-09-23 13:29:19.353 Log level: Normal
. 2021-09-23 13:29:19.353 Local account: LAPTOP-GERRY\gerry
. 2021-09-23 13:29:19.353 Working directory: C:\Program Files (x86)\WinSCP
. 2021-09-23 13:29:19.354 Process ID: 17648
. 2021-09-23 13:29:19.389 Ancestor processes: explorer, ...
. 2021-09-23 13:29:19.390 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2021-09-23 13:29:19.391 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/14/2021, DST End: 11/7/2021
. 2021-09-23 13:29:19.392 Login time: Thursday, September 23, 2021 1:29:19 PM
. 2021-09-23 13:29:19.392 --------------------------------------------------------------------------
. 2021-09-23 13:29:19.393 Session name: gfelice@hsmcohio.org (Site)
. 2021-09-23 13:29:19.393 Host name: hsmcohio.org (Port: 21)
. 2021-09-23 13:29:19.393 User name: gfelice (Password: Yes, Key file: No, Passphrase: No)
. 2021-09-23 13:29:19.393 Transfer Protocol: FTP
. 2021-09-23 13:29:19.393 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2021-09-23 13:29:19.393 Disable Nagle: No
. 2021-09-23 13:29:19.394 Proxy: None
. 2021-09-23 13:29:19.394 Send buffer: 262144
. 2021-09-23 13:29:19.394 UTF: Auto
. 2021-09-23 13:29:19.394 FTPS: None [Client certificate: No]
. 2021-09-23 13:29:19.394 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2021-09-23 13:29:19.394 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2021-09-23 13:29:19.394 Cache directory changes: Yes, Permanent: Yes
. 2021-09-23 13:29:19.394 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2021-09-23 13:29:19.395 Timezone offset: 0h 0m
. 2021-09-23 13:29:19.395 --------------------------------------------------------------------------
. 2021-09-23 13:29:19.509 Connecting to hsmcohio.org ...
. 2021-09-23 13:29:19.509 Connection failed.
* 2021-09-23 13:29:19.620 (EFatal) Connection failed.
* 2021-09-23 13:29:19.620 Connection failed.
. 2021-09-23 13:43:46.494 --------------------------------------------------------------------------
. 2021-09-23 13:43:46.503 WinSCP Version 5.19.2 (Build 11614) (OS 10.0.19043 - Windows 10 Home)
. 2021-09-23 13:43:46.503 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\
. 2021-09-23 13:43:46.504 Log level: Normal
. 2021-09-23 13:43:46.504 Local account: LAPTOP-GERRY\gerry
. 2021-09-23 13:43:46.504 Working directory: C:\Program Files (x86)\WinSCP
. 2021-09-23 13:43:46.504 Process ID: 19452
. 2021-09-23 13:43:46.541 Ancestor processes: explorer, ...
. 2021-09-23 13:43:46.543 Command-line: "C:\Program Files (x86)\WinSCP\WinSCP.exe"
. 2021-09-23 13:43:46.543 Time zone: Current: GMT-4, Standard: GMT-5 (Eastern Standard Time), DST: GMT-4 (Eastern Daylight Time), DST Start: 3/14/2021, DST End: 11/7/2021
. 2021-09-23 13:43:46.544 Login time: Thursday, September 23, 2021 1:43:46 PM
. 2021-09-23 13:43:46.544 --------------------------------------------------------------------------
. 2021-09-23 13:43:46.544 Session name: gfelice@hsmcohio.org (Site)
. 2021-09-23 13:43:46.544 Host name: hsmcohio.org (Port: 21)
. 2021-09-23 13:43:46.545 User name: gfelice (Password: Yes, Key file: No, Passphrase: No)
. 2021-09-23 13:43:46.545 Transfer Protocol: FTP
. 2021-09-23 13:43:46.545 Ping type: Dummy, Ping interval: 30 sec; Timeout: 15 sec
. 2021-09-23 13:43:46.545 Disable Nagle: No
. 2021-09-23 13:43:46.545 Proxy: None
. 2021-09-23 13:43:46.545 Send buffer: 262144
. 2021-09-23 13:43:46.545 UTF: Auto
. 2021-09-23 13:43:46.545 FTPS: None [Client certificate: No]
. 2021-09-23 13:43:46.546 FTP: Passive: Yes [Force IP: Auto]; MLSD: Auto [List all: Auto]; HOST: Auto
. 2021-09-23 13:43:46.546 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes
. 2021-09-23 13:43:46.546 Cache directory changes: Yes, Permanent: Yes
. 2021-09-23 13:43:46.546 Recycle bin: Delete to: No, Overwritten to: No, Bin path:
. 2021-09-23 13:43:46.546 Timezone offset: 0h 0m
. 2021-09-23 13:43:46.546 --------------------------------------------------------------------------
. 2021-09-23 13:43:46.664 Connecting to hsmcohio.org ...
. 2021-09-23 13:43:46.728 Connection failed.
So can you connect from any other machine? Any other network? Did you try contacting your hosting provider/server administrator?
