Maximum filesize
Aquilas
Amsterdam (NL)
Maximum filesize
I need to do a onetime upload of a very large file (about 8 GigaBytes). Both sender and receiver cannot agree on an alternative for FTP and cannot agree on a method to split up the file.
Question:
Is the transfer of such a large file possible with WinSCP?
Re: Maximum filesize
If the connection between the sites is sufficiently fast, it might do.
You might also consider splitting the files to parts and merge them at the destination.
Aquilas
Thanks for the answer. The destination party does not support splitting.
The quality of the connection is good.
I have requested that they at least support a test environment.
