451 Transfer aborted. Input/output error
ipisors
I am getting 451 Transfer aborted. Input/output error and not sure what it means, can anyone help?
Here is last chunk of log file:
< 2021-09-29 06:04:47.715 257 "/CYC/INVENTORY/ECOM" is the current directory
< 2021-09-29 06:04:47.715 Script: /CYC/INVENTORY/ECOM
> 2021-09-29 06:04:47.715 Script: put "C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv"
. 2021-09-29 06:04:47.715 Copying 1 files/directories to remote directory "/CYC/INVENTORY/ECOM" - total size: 69,044
. 2021-09-29 06:04:47.715   PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask:
. 2021-09-29 06:04:47.715   TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; EncryptNewFiles: Yes; ExcludeHiddenFiles: No; ExcludeEmptyDirectories: No; InclM: ; ResumeL: 0
. 2021-09-29 06:04:47.715   AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2021-09-29 06:04:47.716 File: 'C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv' [2021-09-29T13:04:45.900Z] [69044]
. 2021-09-29 06:04:47.716 Copying "C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv" to remote directory started.
. 2021-09-29 06:04:47.716 Binary transfer mode selected.
. 2021-09-29 06:04:47.716 Starting upload of C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv
> 2021-09-29 06:04:47.724 TYPE I
< 2021-09-29 06:04:47.832 200 Type set to I
> 2021-09-29 06:04:47.832 PASV
< 2021-09-29 06:04:47.957 227 Entering Passive Mode (78,47,2,61,233,235).
> 2021-09-29 06:04:47.957 STOR raptor_inv_ecomm.csv
. 2021-09-29 06:04:47.957 Connecting to 78.47.2.61:59883 ...
< 2021-09-29 06:04:48.205 150 Opening BINARY mode data connection for raptor_inv_ecomm.csv
< 2021-09-29 06:04:48.459 451 Transfer aborted. Input/output error
. 2021-09-29 06:04:48.459 Copying files to remote side failed.
* 2021-09-29 06:04:48.459 (ExtException) **Copying files to remote side failed.**
* 2021-09-29 06:04:48.459 Transfer aborted. Input/output error
. 2021-09-29 06:04:48.459 Asking user:
. 2021-09-29 06:04:48.459 Error transferring file 'C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv'. ("Copying files to remote side failed.","Transfer aborted. Input/output error")
< 2021-09-29 06:04:48.459 Script: Error transferring file 'C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv'.
< 2021-09-29 06:04:48.459 Script: Copying files to remote side failed.
< 2021-09-29 06:04:48.459 Transfer aborted. Input/output error
. 2021-09-29 06:04:48.459 Answer: Abort
* 2021-09-29 06:04:48.459 (ESkipFile) Error transferring file 'C:\Users\Administrator\Desktop\Overstock\Projects\SUPPLIER INVENTORY V 2.0\Vendors\Ecommerce Pull Location\Runs\2021-09-29 060403\raptor_inv_ecomm.csv'.
* 2021-09-29 06:04:48.459 Copying files to remote side failed.
. 2021-09-29 06:04:48.459 Copying finished: Transferred: 16,384, Elapsed: 0:00:00, CPS: 0/s
. 2021-09-29 06:04:48.459 Script: Failed
. 2021-09-29 06:04:48.459 Script: Exit code: 1
. 2021-09-29 06:04:48.459 Disconnected from server
Re: 451 Transfer aborted. Input/output error
Does it happen with every file upload? Can you upload the files using any other FTP client running on the same local machine?
