Error message from server: No such file WinSCP v. 5.19.3 (Build 11749)
Hello all,
I have a problem retrieving certain files via get command (4 of them) from a server. The files do exist in the
And just bellow is the same script as run via cmd.
/Reports directory of the server but as seen from the log file I cannot retrieve nor just the first of them. Those commands run from a batch file/script via Task Scheduler. Running the same script from command prompt, does the job nicely and those files along with the other commands complete successfully. Any thoughts?
2021-10-20 07:58:03.173 -------------------------------------------------------------------------- . 2021-10-20 07:58:03.173 WinSCP Version 5.19.3 (Build 11749) (OS 10.0.18362 - Windows 10 Enterprise) . 2021-10-20 07:58:03.174 Configuration: HKCU\Software\Martin Prikryl\WinSCP 2\ . 2021-10-20 07:58:03.174 Log level: Normal . 2021-10-20 07:58:03.174 Local account: TMNA\theuser . 2021-10-20 07:58:03.174 Working directory: C:\WINDOWS\system32 . 2021-10-20 07:58:03.174 Process ID: 13652 . 2021-10-20 07:58:03.196 Ancestor processes: WinSCP, cmd, ... . 2021-10-20 07:58:03.196 Command-line: "C:\Users\theuser\AppData\Local\Programs\WinSCP\WinSCP.exe" /console=5.19.3 /consoleinstance=_21876_872 "/script=D:\theuser\Transmission\Reports\ScriptLogs\PoTP\myscript_PoTP.txt" "/log=D:\theuser\Transmission\Reports\ScriptLogs\PoTP\logWinSCP_20211020.log" "/loglevel=0" . 2021-10-20 07:58:03.201 Time zone: Current: GMT+3, Standard: GMT+2 (GTB Standard Time), DST: GMT+3 (GTB Daylight Time), DST Start: 28/3/2021, DST End: 31/10/2021 . 2021-10-20 07:58:03.202 Login time: Τετάρτη, 20 Οκτώβριος 2021 7:58:03 πμ . 2021-10-20 07:58:03.202 -------------------------------------------------------------------------- . 2021-10-20 07:58:03.202 Script: Retrospectively logging previous script records: > 2021-10-20 07:58:03.202 Script: open sftp://theuser:***@<theIP>/ -hostkey="ssh-ed25519 255 ******************" . 2021-10-20 07:58:03.202 -------------------------------------------------------------------------- . 2021-10-20 07:58:03.202 Session name: theuser@<theIP> (Ad-Hoc site) . 2021-10-20 07:58:03.202 Host name: <theIP> (Port: 22) . 2021-10-20 07:58:03.202 User name: theuser (Password: Yes, Key file: No, Passphrase: No) . 2021-10-20 07:58:03.202 Tunnel: No . 2021-10-20 07:58:03.202 Transfer Protocol: SFTP . 2021-10-20 07:58:03.202 Ping type: Off, Ping interval: 30 sec; Timeout: 15 sec . 2021-10-20 07:58:03.202 Disable Nagle: No . 2021-10-20 07:58:03.202 Proxy: None . 2021-10-20 07:58:03.202 Send buffer: 262144 . 2021-10-20 07:58:03.202 SSH protocol version: 2; Compression: No . 2021-10-20 07:58:03.202 Bypass authentication: No . 2021-10-20 07:58:03.202 Try agent: Yes; Agent forwarding: No; TIS/CryptoCard: No; KI: Yes; GSSAPI: Yes . 2021-10-20 07:58:03.202 GSSAPI: KEX: No; Forwarding: No; Libs: gssapi32,sspi,custom; Custom: . 2021-10-20 07:58:03.202 Ciphers: aes,chacha20,blowfish,3des,WARN,arcfour,des; Ssh2DES: No . 2021-10-20 07:58:03.202 KEX: ecdh,dh-gex-sha1,dh-group14-sha1,rsa,WARN,dh-group1-sha1 . 2021-10-20 07:58:03.202 SSH Bugs: Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto,Auto . 2021-10-20 07:58:03.202 Simple channel: Yes . 2021-10-20 07:58:03.202 Return code variable: Autodetect; Lookup user groups: Auto . 2021-10-20 07:58:03.202 Shell: default . 2021-10-20 07:58:03.202 EOL: LF, UTF: Auto . 2021-10-20 07:58:03.202 Clear aliases: Yes, Unset nat.vars: Yes, Resolve symlinks: Yes; Follow directory symlinks: No . 2021-10-20 07:58:03.202 LS: ls -la, Ign LS warn: Yes, Scp1 Comp: No; Exit code 1 is error: No . 2021-10-20 07:58:03.202 SFTP Bugs: Auto,Auto . 2021-10-20 07:58:03.202 SFTP Server: default . 2021-10-20 07:58:03.202 Local directory: default, Remote directory: home, Update: Yes, Cache: Yes . 2021-10-20 07:58:03.202 Cache directory changes: Yes, Permanent: Yes . 2021-10-20 07:58:03.202 Recycle bin: Delete to: No, Overwritten to: No, Bin path: . 2021-10-20 07:58:03.202 DST mode: Unix . 2021-10-20 07:58:03.202 -------------------------------------------------------------------------- < 2021-10-20 07:58:03.202 Script: Searching for host... . 2021-10-20 07:58:03.203 Looking up host "<theIP>" for SSH connection . 2021-10-20 07:58:03.203 Connecting to <theIP> port 22 < 2021-10-20 07:58:03.216 Script: Connecting to host... . 2021-10-20 07:58:03.216 We claim version: SSH-2.0-WinSCP_release_5.19.3 . 2021-10-20 07:58:03.253 Remote version: SSH-2.0-OpenSSH_8.2 . 2021-10-20 07:58:03.253 Using SSH protocol version 2 . 2021-10-20 07:58:03.254 Have a known host key of type ssh-ed25519 . 2021-10-20 07:58:03.267 Doing ECDH key exchange with curve nistp256 and hash SHA-256 . 2021-10-20 07:58:03.356 Server also has ecdsa-sha2-nistp256/ssh-rsa host keys, but we don't know any of them . 2021-10-20 07:58:03.357 Host key fingerprint is: . 2021-10-20 07:58:03.357 ssh-ed25519 255 ************** < 2021-10-20 07:58:03.357 Script: Authenticating... . 2021-10-20 07:58:03.357 Host key matches cached key . 2021-10-20 07:58:03.358 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] outbound encryption . 2021-10-20 07:58:03.358 Initialised HMAC-SHA-256 outbound MAC algorithm . 2021-10-20 07:58:03.358 Initialised AES-256 SDCTR (AES-NI accelerated) [aes256-ctr] inbound encryption . 2021-10-20 07:58:03.359 Initialised HMAC-SHA-256 inbound MAC algorithm ! 2021-10-20 07:58:03.369 Using username "theuser". < 2021-10-20 07:58:03.369 Script: Using username "theuser". ! 2021-10-20 07:58:03.417 Authorized users only. All activities may be monitored and reported. . 2021-10-20 07:58:03.417 Server offered these authentication methods: publickey,password . 2021-10-20 07:58:03.417 Prompt (password, "SSH password", <no instructions>, "&Password: ") . 2021-10-20 07:58:03.417 Using stored password. < 2021-10-20 07:58:03.417 Script: Authenticating with pre-entered password. . 2021-10-20 07:58:03.417 Sent password . 2021-10-20 07:58:03.444 Access granted . 2021-10-20 07:58:03.445 Opening main session channel . 2021-10-20 07:58:03.457 Opened main channel . 2021-10-20 07:58:03.472 Started a shell/command < 2021-10-20 07:58:03.472 Script: Authenticated. . 2021-10-20 07:58:03.473 -------------------------------------------------------------------------- . 2021-10-20 07:58:03.473 Using SFTP protocol. . 2021-10-20 07:58:03.474 Doing startup conversation with host. < 2021-10-20 07:58:03.474 Script: Starting the session... > 2021-10-20 07:58:03.475 Type: SSH_FXP_INIT, Size: 5, Number: -1 < 2021-10-20 07:58:03.486 Type: SSH_FXP_VERSION, Size: 179, Number: -1 . 2021-10-20 07:58:03.486 SFTP version 3 negotiated. . 2021-10-20 07:58:03.486 Unknown server extension posix-rename@openssh.com="1" . 2021-10-20 07:58:03.486 Supports statvfs@openssh.com extension version "2" . 2021-10-20 07:58:03.486 Unknown server extension fstatvfs@openssh.com="2" . 2021-10-20 07:58:03.486 Supports hardlink@openssh.com extension version "1" . 2021-10-20 07:58:03.486 Unknown server extension fsync@openssh.com="1" . 2021-10-20 07:58:03.486 Unknown server extension lsetstat@openssh.com="1" . 2021-10-20 07:58:03.487 We believe the server has signed timestamps bug . 2021-10-20 07:58:03.487 We will use UTF-8 strings until server sends an invalid UTF-8 string as with SFTP version 3 and older UTF-8 strings are not mandatory . 2021-10-20 07:58:03.487 Limiting packet size to OpenSSH sftp-server limit of 262148 bytes . 2021-10-20 07:58:03.487 Getting current directory name. . 2021-10-20 07:58:03.487 Getting real path for '.' > 2021-10-20 07:58:03.487 Type: SSH_FXP_REALPATH, Size: 10, Number: 16 < 2021-10-20 07:58:03.497 Type: SSH_FXP_NAME, Size: 23, Number: 16 . 2021-10-20 07:58:03.498 Real path is '/' . 2021-10-20 07:58:03.498 Startup conversation with host finished. < 2021-10-20 07:58:03.498 Script: Session started. < 2021-10-20 07:58:03.498 Script: Active session: [1] theuser@<theIP> > 2021-10-20 07:58:03.500 Script: lcd D:\theuser\Transmission\Reports\PoTP_SFP < 2021-10-20 07:58:03.500 Script: D:\theuser\Transmission\Reports\PoTP_SFP > 2021-10-20 07:58:03.502 Script: cd Reports . 2021-10-20 07:58:03.502 Cached directory change via "Reports" to "/Reports". . 2021-10-20 07:58:03.502 Getting current directory name. < 2021-10-20 07:58:03.502 Script: /Reports > 2021-10-20 07:58:03.503 Script: get "PM_IG500011_15_202110200000Z_01.csv.gz" . 2021-10-20 07:58:03.504 Listing file "PM_IG500011_15_202110200000Z_01.csv.gz". > 2021-10-20 07:58:03.504 Type: SSH_FXP_LSTAT, Size: 56, Number: 263 < 2021-10-20 07:58:03.516 Type: SSH_FXP_STATUS, Size: 29, Number: 263 < 2021-10-20 07:58:03.516 Status code: 2, Message: 263, Server: No such file, Language: < 2021-10-20 07:58:03.517 Script: Can't get attributes of file 'PM_IG500011_15_202110200000Z_01.csv.gz'. < 2021-10-20 07:58:03.517 No such file or directory. < 2021-10-20 07:58:03.517 Error code: 2 < 2021-10-20 07:58:03.517 Error message from server: No such file . 2021-10-20 07:58:03.518 Script: Failed . 2021-10-20 07:58:03.518 Script: Exit code: 1 . 2021-10-20 07:58:03.518 Closing connection. . 2021-10-20 07:58:03.518 Sending special code: 1 . 2021-10-20 07:58:03.535 Session sent command exit status 0 . 2021-10-20 07:58:03.535 Main session channel closed . 2021-10-20 07:58:03.536 All channels closed
C:\Users\theuser\AppData\Local\Programs\WinSCP>cronedWinSCP_PoTP.bat 20211020 2021 10 20 Searching for host... Connecting to host... Authenticating... Using username "theuser". Authenticating with pre-entered password. Authenticated. Starting the session... Session started. Active session: [1] theuser@<theIP> D:\theuser\Transmission\Reports\PoTP_SFP /Reports PM_IG500011_15_2021102000 | 40 KB | 189,2 KB/s | binary | 100% PM_IG500012_15_2021102000 | 36 KB | 161,1 KB/s | binary | 100% PM_IG500011_1440_20211018 | 6 KB | 0,0 KB/s | binary | 100% PM_IG500012_1440_20211018 | 5 KB | 0,0 KB/s | binary | 100% The most recently created file is PM_IG500012_1440_202110182100Z_01.csv C:\Users\theuser\AppData\Local\Programs\WinSCP>
