Synchronize - After the command, the batch isn't interrupted
Hello, adding to my batch the
This is my script:
synchronize command, the script don't terminate. It works as intended, but the script won't terminate, as it do removing the command. Am I doing something wrong?
This is my script:
@echo off "C:\Program Files (x86)\WinSCP\WinSCP.com" ^ /xmllog="%logsfolder%\%data%_%ora%-[Upload].xml" /ini=nul ^ /command ^ "open ftp://**************************/" ^ "lcd ""%axfs%\BtoE\""" ^ "cd /import" ^ "put *.CSV" ^ "lcd ""%axfs%\Leaflet""" ^ "cd /attachments/leaflet" ^ "synchronize remote" "exit"
