Connection upload to AS400
Miles
Germany
I try to upload a file to AS400, but it doesn't work well.
My FTP works well:
open Server
put file lib/file (replace
quit
I try this with WinSCP.com, but I get this error:
Cannot overwrite remote file '/qsys.lib/xxx.lib/xxx.file'.
General failure (server should provide error description).
Error code: 4
Error message from server: Failure
Common reasons for the Error code 4 are:
- Renaming a file to a name of already existing file.
- Creating a directory that already exists.
- Moving a remote file to a different filesystem (HDD).
- Uploading a file to a full filesystem (HDD).
- Exceeding a user disk quota.
(D)elete, (A)bort, (R)etry, (S)kip, Ski(p) all: Abort
I also try with (replace but then the same message, but not with the correct file name.
Can someone help?
Re: Connection upload to AS400
Did you try doing something like cd lib, put file?
