I Hate Version 5.19.4
aksarben
I've never had problems with WinSCP updates until now.
I just installed version 5.19.4, and to my dismay, it automatically reconnects closed sessions when I launch the program.
I HATE applications that think they're smarter than I an, and do things I didn't request.
Even worse, I can't find a way to turn off this behavior.
How can I disable automatic reconnects?
Re: I Hate Version 5.19.4
Can you please be more specific about the situation, in which WinSCP automatically reconnects session and previously did not? What version were you using before?
I install updates as soon as I learn off them, so I assume my previous version was 5.19.3 (?)
SCENARIO:
1. I launch the app, and enter the master password.
2. The app creates a new session, with the local folder in the left pane, and the host folder in the right pane.
3. I later disconnect the session, so the host folder into disappears, but the right pane stays open, and the app is still running.
4. I later click the X at the top right of the window, and get the usual confirmation dialog, asking, Terminate session XXX and close application?
5. I click the OK button, and app terminates gracefully, with no error message shown.
6. When I later re-launch the app (Step 1 above), it starts normally. At this point I expect it to show root folder of both the local and remote panes (my default). Instead, the right pane shows the remote folder that was displayed before I disconnected the previous session.
I don't recall this happening before the latest version upgrade. Is my memory faulty, or is this behavior new?
bblackmoor
Configuration
Remembering the previously used directories:
Session >> Sites >> Site Manager ... >> (select a site in the left pane)
>> Edit >> Advanced ... >> Environment/Directories >> Remember last used directory
@aksarben: From your description I assume your setup is:
Environment > Window > Workspaces > Automatically save workspace on exit
Environment > Windows > Miscellaneous > Show Login dialog on startup and when the last session is closed = Off
With that setup, WinSCP restores the previous workspace on startup automatically.
But it won't connect any session.
It would connect a session only if:
– You explicitly selected the workspace or session on an initial Login dialog (assuming your have the latter option On).
– You have started WinSCP with workspace/session name on its commandline
Afaik, nothing has changed about this behavior in any recent version of WinSCP.
If you have a different experience, we will need more detailed step-by-step instructions for reproducing the problem. Some screenshots might help too.
