Name column doesn't stay expanded when dragged
honeyandoatmeal
I'm running WinSCP 5.19.4 on Windows 11. I'm experiencing an issue where the "Name" column doesn't stay expanded when dragged. It just immediately snaps back to its original position. This makes seeing long filenames difficult.
Re: Name column doesn't stay expanded when dragged
Can you reproduce the problem, if you start WinSCP with the default configuration?
winscp.exe /ini=nul
