Same key rejected for WinSCP but not for PuTTY
nilsola
Sweden
Winscp 5.19.4, connecting to OpenBSD 7.0 stable.
transfer protocol SFTP
Utgåva Windows 10 Pro
Version 21H1
Installerad ‎2021-‎02-‎06
OS-version 19043.1288
Gränssnitt Windows Feature Experience Pack 120.2212.3920.
I have a pubkey that I have used for a long time.
After upgrading OpenBSD to 7.0 stable the key is rejected by the server for
WinSCP but not for PuTTY.
When connecting from PuTTY I get this log message in the sever /var/log/authlog:
Nov  5 23:03:14 evelina sshd[53945]: Accepted publickey for nilsola from 176.10.218.229 port 52231 ssh2: RSA SHA256:A4EFYBSpgYTB4gYo3WxTpSMki3EqRHoUD0iOa4WFuPM
When connecting from WinSCP I get this message in the server /var/log/authlog:
Nov  5 22:49:56 evelina sshd[28222]: userauth_pubkey: key type ssh-rsa not in PubkeyAcceptedAlgorithms [preauth]
It is the same key. Since this is a RSA/SHA256 key it should work also for WinSCP.
(After adding PubkeyAcceptedAlgorithms=+ssh-rsa in the server sshd_config it works also for WinSCP.)
See also:
https://marc.info/?l=openssh-unix-announce&m=161880182302909&w=2
https://marc.info/?l=openbsd-tech&m=163028217802671&w=2
  • evelina.log (146.99 KB, Private file)
gclaborn
Inverse problem (key works in WinSCP but not in PuTTY)
Such a strange occurrence. I've used this key to login to servers running CentOS, Alma, Rocky and Debian, but for some reason on Ubuntu WinSCP can use the key while launching PuTTY from WinSCP fails. Launching PuTTY manually with a different session name and same key fails.
While WinSCP is benefiting in my case; I wonder if the same difference caused your situation. Something apparently works differently than PuTTY's session start does, though they share the same settings panel. Very odd.
