Drag & Drop moves instead of copying.
(Windows 10 1809, WinSCP 5.14.2, 5.19.3, 5.19.4).
Dragging a file from remote into an application sometimes deletes the file after the application receives it.
When I dragged a file from remote into WinMerge, I noticed the remote file window refreshed, and the original file was gone, now only existing in
I've attached some configs, and a debug-2 log file.
This is a fresh install of Windows 10, I seem to recall encountering and defeating this issue before, but I can't recall how I did it.
If there is a workaround for this version of Windows (I can't yet upgrade), which version should I download?
%TEMP%. I tried again, with LibreOffice Writer, and the same thing happened. However, dragging the file into a new Notepad++ file, resulted in the file staying put on remote.
