WinSCP fails to run as a WebJob on Azure App Service
I've developed a .NET console application to run as a WebJob under Azure App Service.
This console app is using WinSCP to transfer files from App Service Filesystem to an on-prem FTP Server.
1- An Exception is being fired intermittently on ALL of our Azure environments (Dev, Test, Prod)
2- The connectivity between App Service & the on-perm FTP server is Okay.
3- Most of the time the job succeeds ,the files are synced, and log files written as well.
4- Sometimes, the job fails, no files synced, and no Log is NOT being written as well.
Any clues?WinSCP process terminated with exit code -1073741819 (C0000005). There was no output. Response log file D:\local\Temp\wscp550C.03E988EE.tmp was not created. This could indicate lack of write permissions to the log folder or problems starting WinSCP itself.
