Need to Change file name for some specific files whose starting is same letters
@echo off "C:\Program Files (x86)\WinSCP\WinSCP.com" ^ /log="C:\Program Files (x86)\WinSCP\logs\AutoTransfer.log" /ini=nul ^ /command ^ "open sftp://serverdetails/ -hostkey=""ssh-rsa 2048 XXXXXXX""" ^ "lcd E:\DSU\serverdetails\usr\sftpuser\DSU\DATA\OUT" ^ "cd /EInvoice" ^ "put -rawtransfersettings[1] FileNameCase=1 Documents_Action_*.* " ^ "put -rawtransfersettings[1] FileNameCase=0 *.* " ^ "exit" set WINSCP_RESULT=%ERRORLEVEL% if %WINSCP_RESULT% equ 0 ( echo Success ) else ( echo Error ) exit /b %WINSCP_RESULT%
But in local directory there are multiple files which are starting from same letters (
Documets).
I want to move some specific files (
Documents_Action) to be in upper case while transferring remote directory.
Currently both files are moving in but (
Documents_Action) is moving in both type "uppercase" and "no change".
Please help
