Comparing window don't show TARGET (direction)
Waruwaru
Deutschland
If you want to synchronize server and local, you can do it in one or both directions. The small window that then appears ("Comparing") unfortunately no longer shows which direction is being processed, which sometimes gives you an uneasy feeling.
I would appreciate it very much, if during the processing of the data would be displayed, what the target is. Especially if you let it replace directly without the overview.
In this window is local the target, I hope so :D
Maybe, it would be enough to write in the window-title like:
  • Comparing – Prepare download
  • Comparing – Prepare upload
  • Comparing – fit both sides
Waruwaru
Deutschland
My request is not about the length of the paths. I would like to see in the window if the data is synchronized to the server or on the computer(local) or both directions.
It can happen quickly that you start a synchronization that runs in the wrong direction (wrong target), but you don't notice it anymore because in the small window the direction of the synchronization is no longer named.
